chrisv_s 1
I run an Avermedia NV5000 DVR for my CCTV system. This uses standard analogue composite cameras. Is there support to grab the camera streams from this device in the same way as IP cameras? I believe it is possible somehow as I have an App on the iPad called IP Cam Viewer that allows me to view individual camera channels over HTTP.
Has anyone had any success with doing something like this? Any support with this would be most appreciated.
Chris
[ Added: 2013-11-24, 22:59 ]
UPDATE:
I have successfully got JPEGs to work by digging around a bit more on the internet and finding the right path to use. I have copied this into both JPEG and MJPG paths so can see a static image on the PC (not showing on the phone however). Can anyone help with getting a live stream?
