stevenvd 51
I still can't get this to work! The image below is just a test scene. It should turn on the light (or the tv) 55 minutes after the variable has changed. But it turns on direclty! Can someone please help me out?!
(example is from:
)And I don't want to do it with 3300 seconds of waiting or LUA
I found A bug in the code. When you change the Graphic to LUA you see this:
With this line:
it will ofcourse always trigger directly!
6 answers to this question
