How does this: DeviceID = {10, 12, 24} work?
Guest jschun
Does anybody have a short and sweet example how to use the {xx, xx, xx} in LUA?
I want to arm multiple DoorSensors, but I don't want to do it like:
But I want to do it like:
But I do not know the exact syntax to get all three sensors to be armed
Can anyone help please?
Thanks!!
8 answers to this question
jschun,
DoorSensorID[1] give you the first value in the table... [2] the second ...
Regards
Guest jschun
    Thank you for your quick and clear response Krikroff!
    two loops possible i is index v is value in table element
    Guest jschun
    Thanks RobMac! I used the first example in my scripts and it works like a charm! ッ
    I'm not quite sure what to do with the index / value example though. Can you explain a bit more on that?
    Thanks in advance ッ
    Thanks in advance ッ
    The enumerator is just a nice way to get the integer index and the table value in variables to use within a loop rather than creating a counter.
    Also you can index with a string and that is nice as you can use notify function with the device name or just debug without having to look up the device... notice pairs not ipairs when you use string index
    as you can store tables in tables the second part of the code is possible and then you have room and device.
    you could of course get the strings from calls to functions in the first place in the table declaration rather then using strings like "Drawing" (if fibaro API had function)
    you can also store actual functions in tables so lots of uses but I will leave that for another post
    robmac,
    Thanks a lot for your programming tips in LUA. I like the following piece, however wonder why the results are in such a strange sequence?
    local devices = { ["main"] = 184,
                      ["side"] = 185,
                      ["other"] = 186 }
    for i,v in pairs(devices ) do
              fibaro:debug(i)
              fibaro:debug(v)
    results:
    richo, pairs(table) allow iteration but the order that items are returned is not defined. You must use ipairs, with ipairs(table) the order in which elements are returned is guaranteed to be in the numeric order of the indices, but non-integer keys are simply skipped (your example certainly does not work).
    if robmac wants complete
    /emoticons/default_icon_biggrin.gif" alt=":-D" /> (thank to him for his good advice)
    from the luascheduler... see the table.sort that makes sure that the catchup events are played in the correct sequence by time
