How to start a scene with association
Guest Charly
I am using a Home Center 2 with software 3.571.
Have a bedroom light switch on by FGS211 Switch now I would like to use the push button (connected on S1) to start scene, is this possible and how would it be done.
The scene should start on double click the button. In the scene I switch on the light in the bedroom, the landing and the bathroom for about 5 minutes.
4 answers to this question
Guest jschun
    Hello Charly,
    I think you can do this by setting Parameter 14 to Momentary Switch (on advanced tab of your switch) and then read the text at the bottom about Parameter 41.
    Good luck!
    Rgrds,
    Jerry
    You have to enable parameter 41 and use some code like this (you have to change 20 to the ID of the switch that starts the scene):
    Didn't test it, good luck!
    Guest Charly
    Hello Remko,
    Thanks for your script. However there is no Parameter 41 on this switch FGS211 Switch 3kW. Version 1.9
    Charley
    You are right.... I was confussing with a dimmer (that's how I use it) and from 1.9 you have parameter 41 with a dimmer.
