rb338 5
I've got several WiFi RGBW LED controllers which I can control with apps for Android and iOS.
Now, my goal is to make a virtual device in the HC2 so I can control the LEDs from there. To reverse engineer the protocol, I installed an Android client with the app on my PC and enabled Wireshark to find out what happens.
I'm a total newbie on this area, so maybe anyone can help out here?
First step: turn it on and off.
What did I do: start Wireshark, make the app connect, push power (turns it off) and push power again (turns it on).
What do I see?
Every second the app sends a package (length: 1, data: ff).
When I push the power button it sends a package (length: 12, data: 5535656302000212a9bfaaaa)
When I push powe again it sends a package (length: 12, data: 5535656302000212abc1aaaa)
When I "follow" the TCP package and show it as a C array, it tells me:
char peer1_0[] = {
0x55, 0x35, 0x65, 0x63, 0x02, 0x00, 0x02, 0x12,
0xa9, 0xbf, 0xaa, 0xaa };
char peer1_1[] = {
0xab, 0xc1, 0xaa, 0xaa };
I've included a screenshot as well.
Can anyone help me along? Once I can get the on/off commands to the device, I can figure out how to control R, G, B and W using a slider
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />For example, I don't know in what format I have to send the package. I'm also not sure if the 1 byte ff package every second is necessary, this might be just a keep-alive for the connection.
Thanks for any help!!
