Does anyone have good solution how to cover DS18B20 sensors If I will be using these instead of wall thermostats to monitor room temperature. There are thermostat boxes on the wall and I can use same wires to connect DS18B20 to universal sensor.
BUT how to close the box so that the temperature values will be correct - I think if I close the box with blind cover, then the temperature will be alittle bit lower inside the box.
Does anyone have good solution on this? It has to look nice also and shouldnt be handcraft because I think I would be using this alot.
Thank you!
what about this enclosure :
Guest Lode
I have this one and looks very nice.
