Hi All
I have a wall plug that is working fine but the illumination doesn't work !!!
I checked parameter 61, it is set to 1. I tried to set it to 3, without change !!!!
The illumination is well displayed into the HC2 web interface !!!
Is there some bugs like that with wall plugs ?
Did you try to reset the wall plug?
1) Insert Plug into a socket
2) Press and hold the B button for 15-20 seconds until LED ring glows yellow
3) Release the B button
4) Press the B button briefly
Guest Lode
Did you try a reset ?
Posted at the same minute Lambik
Postend at the same minute Lambik
Brain-Z-Wave on the same frequency perhaps?
    I did a reset and it's fine now
    /emoticons/default_icon_redface.gif" alt=":oops:" />
    Thanks for your help
    David
    Your welcome.
    Guest Lode
    Hahaha........i guess....
    /emoticons/default_icon_idea.gif" alt=":idea:" />
