Need help with scene conditions
I need to create scene, which will run with some conditions.
When the motion sensor is tripped, the light should be dimmed on 15% and turned off after 3 min. But if I turn the light on manually on 100% witin 3 minutes, it shouldn't be turned off automatically.
I've created a "scene 1" with conditions:
* Motion sensor is tripped
AND
* Light is off
AND
* illumination lower then 3 lux
THEN
* Light dim on 15%
* Run "scene 2" after 3 minutes
And I've created "scene 2" which conditions:
* Light is on and volume less than 50%
THEN
* Light should be turned off
But
The light only turns on and turns off after 3 minutes. If in this 3 minutes I turn on it, the light turns off anyway.
