I have 3 wires coming from wall, 1 wire is live other 2 wires are for 2 buttons.
How can i connect dimmer to this switch?
1 switch have 2 buttons and i have 2 switches with 4 buttons. Switch at the right is original setting.
[ Added: 2013-12-06, 05:15 ]
Before i kill myself i found this:
1 dimmer is only for 1 zone.
I have to use 2x1.5 relay but it needs 3 wired system which i dont have;
LOL
Is there any ready package or relay for my wire system in market?
Guest Kuuno
easiest way is to put 2 dimmers behind the switch and 2 dimmers behind 2 lamps and make the associations so dimmer1 switch 2 triggers dimmer2
do you have some connecting box above the ceiling? from there you can maybe rewire a neutral wire to the switchs
ps-the blue wires should me market(painted maybe) so they are not misleading.
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> blue is always neutral
    easiest way is to put 2 dimmers behind the switch and 2 dimmers behind 2 lamps and make he associations so dimmer1 switch 2 triggers dimmer2
    I have 1 live and 2 wire for lamb; how can i use 2 dimmers?
    Yes but i dont want to call electrician; this is the easy way.
    Yes your right, generally electricians here are not educated so they dont know what color is for:) They only look if electric is working.
    Ok my questions;
    1-I have 1 live and 2 wire for lamp; how can i use 2 dimmers?
    2-If i put 2 wires which are for lamps to "O" is this secure?
    3-When i make normal wiring with only for 1 zone(1 lamp) i hear some "zzzzzzzzzzzzz" sound in the ELECTRICAL PANEL.
