[fixed] Door sensor stuck - led light continuously on
After I accidentally dropped one of my door/window sensor it was stuck with a continuously burning led light and didn't respond to anything. After a few hour of fiddling around I found that the solution is pretty simple.
In my case the magnetic sensor inside the casing (small glass tube) was stuck. Giving it a few gentle nudges with a ballpoint pen somehow put everything back into place and the sensor started working again!
