all off function
Guest Kuuno
Guest Kuuno
in some bigger prjects (houses arond 300+m2) i see that all lights off(from ipad) does not sometimes do that. (some lights stay on) and i think it is because the all off signal might not get there every time... when i click manually off then it works so maybe this should be solved some other way like a scene that turns off and checks if lights are really off
any ideas?
6 answers to this question
With what brand of device ? Only Fibaro products ?
It seems to me that you can enable or disable the reaction for "all off" frame, i deactivated it on almost all actuators.
Guest Kuuno
    i have enabled it for all lights and this is the way i need it but the command does not always get to all devices...
    I have never trusted it in my property >300m2.
    I use a lua loop by room and device with pauses and find it is more reliable but not 100%.
    Majority of modules are fibaro v1.4, 1.9 and 2.1. Version not relevant or distance as far as I can tell as failures are random. Sometimes spare room is not switched and that is only 3m from HC2.
    Sorry not to be able to give you hope of 100% reliability on HC2 for this function.
    Hi
    Is it a function available only on the IPad ?
    David
    Also on iPhone; when in the lighting menu, it's a small light-bulb in the top left corner
    On Android, I ve got it by room but not at the whole lights level.....
