Using API with Arduino
Hope somebody can help me...
I want to use my Arduino Uno for sending a http request to HC2 for turning off a light. When I enter
"http://admin:[email protected]:80/api/callAction?deviceID=7&name=turnOff"
into the address bar of my browser, the light nicely turns off.
I tried the following code for the Arduino, but with no succes:
I tried different things like PUT and POST and different examples I found on different forums. The serial monitor of the Arduino IDE prints "connected", so I assume a connection is established with the HC2. I'm not that familiar with http requests so any help is appreciated
/emoticons/default_icon_biggrin.gif" alt=":-D" />.
Thanks in advance.
14 answers to this question
gilbert, try with on the same line
. Perhaps try encode url
but I don't know much about this platform... Good luck
The reason your browser is successfull is because you are logged in to the HC2 with a session. But you don't enter your credentials with your arduino code...
So you have to find out how to add that. I am very interested in the code you are building. Was thinking of building a Arduino device with a Keypad, rfid, and tts engine for arming and disarming the alarm with voice feedback. What kind of arduino and module do you use?
    Krikroff, thanks for your reply. I will try this tonight.
    stevenvd, I hoped using
    would log into the HC2. But 'm not sure it works correctly.
    I use an Arduine Uno Rev3 with an ethernet shield (Wiznet W5100) from dealextreme.
    You can also try
    or put basic authentification (encoded in Base64) in header:
    cf.
    regards.
    Krikroff Thanks for your help, appreciate it. I tried a lot of things, but with no succes. I think indeed the problem is with the authorization.
    As I did not found examples for http communication between Arduino and HC2, I found enough examples of http communication between Arduino and Vera from micasaverde. I assume it also needs authorization, but I don't know the Vera.
    Nevertheless, I made some progress. I managed to create a TCP connection between HC2 and Arduino. To do this I created a virtual device button with the following code:
    The Arduino can read this code and send back an acknowledgement using the following code:
    However, to get information from Arduino, HC2 has to poll the Arduino, for example each x seconds in the main loop of the virtual device. I know this isn't the best solution, but for me it will work for the things I want to achieve.
    Still, any suggestions and tips are welcome
    gilbert, have you try to add a custom header to your http request with
    ? normally it should work...
    I tried:
    where xxxxx is the base64 encoded text of username:password (encoding at
    But without succes...
    /emoticons/default_icon_confused.gif" alt=":-?" />
    Guest rafal_ll
    I tried:
    Solved the problem?
    Did you manage to get it working? I want to build a wall thermostat and Alarm panel on an Arduino with a 4d systems touchscreen and Wifi shield.
    Is it possible to tunnel through with API commands on Fibaro remote service?
     doubt that you can.
    Guest samuelboerhoop
    gilbert or others how did you solve the problem?
    I have a arduino nano with en enc28j60 ethernet module.
    a webserver, with a webpage is working, with 4 inputs and 4 outputs, displaying.
    From my HC2 I can sent commands to the arduino nano to switch on/off the relays, when i go to the webserver from the arduino nano on the webpage i am able to switch on/off the relays too.
    Now I have to arrange the inputs feedback and output feedback towards the fibaro hc2 isn't working yet.
    if someone needs my arduino sketch let me know.
    when i type this line below in a normal browser it will trigger by means of a VD button a global variable.
    So i need to convert this to arduino language to sent to the fibaro hc2
    login = loginname from hc2
    password = password from hc2
    ip-address-hc2 = ip address from Hc2
    deviceid = device id from virtual device
    last digit 1 = number button
    love to hear from you guys
    Gilbert: you said: However, to get information from Arduino, HC2 has to poll the Arduino, for example each x seconds in the main loop of the virtual device.
    What is the code you put in de main loop to read the response ? Thanks for sharing
    #include <Ethernet.h>
    #include <SPI.h>
    #include "RestClient.h"
    RestClient client = RestClient("192.16.1.136"); //IP Home Center
    //Setup
    void setup() {
      Serial.begin(9600);
      // Connect via DHCP
      Serial.println("connect to network");
      client.dhcp(); //DHCP IP
      Serial.println("Setup!");
    String response;
    void loop(){
      response = "";
      client.setHeader("Authorization: Basic XXXXXXXXXX"); //In base 64 user: password
      int statusCode = client.get("/api/sceneControl?id=id&action=start", &response); //code to execute the id scene
      Serial.print("Status code from server: ");
      Serial.println(statusCode);
      Serial.print("Response body from server: ");
      Serial.println(response);
      delay(1000);
