New Remote access
We present you a new remote access, where we change not only graphic design, but we offer new functionality too such as
- The possibility of naming HC2 for better identify
- Automatic detection is server got connection to the HC2
- Remote access detect firmware version of HC2 and automatic load him or the most current version
Very nice update, thank you, run very fast
Two problems I have found so far:
A) Cannot log out from HC2 when using remote access. It means I cannot change between users
B) Updates or "Force update" do not work when activated from remote access.
Lauri
[ Added: 2014-01-04, 15:47 ]
C) If using older soft version than 3.580 then arm/disarm buttons are not visible from home.fibaro.com
Lauri
[ Added: 2014-01-08, 13:43 ]
It seems home.fibaro.com has connection issues. I cant access any of the HC2-s right now remotely.
I have one problem
i try to upload a virtual device:
I have the error message:
"Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request POST /api/importVirtualDevice.
Reason: Error reading from remote server"
I go through a proxy, and I do not know if the error message comes from me or you.
But this is not a usual message from my proxy ...
an idea?
    acidric, upload icons and virtual devices is posible now only in local access
    Hi A.Socha, nice work.
    It almost work on my Windows phone en tablet!
    I have some tips:
    1. The url
    give a security warning on the IPAD, because the username en password are inside the url!
    2. The url
    don’t work in Microsoft IE because the username en password are inside the url!
    3. The url
    don’t work on the Microsoft phone because IE on the phone remove username en password inside the url! So I get a nice screen with Fibaro mobile, but I can’t use it because I didn’t login
    4. The url
    has the wrong language “pl”, in my case it must be “nl” (when I change it manual its work fine)
    5. Can you store the username and password inside standard username en password reminder future of the browser, instead of inside the url? Other option is put it on the end of the url like ?name=admin?password=1234
    Thx, Herke
    I understand this choice for security reasons.
    But would not it be possible that it is an option?
    Now he'll have to mount a remote access in order to work remotely.
    Herke, thank you for your opnion. We will discuss further improvements.
    Krystian,
    Thank you for your response...
    Herke
    I cant access for some reason today, may it have something with the update?
    i go on home.fibaro. There i find my HC2 and i click the gears to get further in as usual, but i end up on a blank page that never loads?
    Edit: I got it working again. A couple of hours later it worked again. Dont know why that happen.
    I am on HCL and have already reported in another thread (
    ) that remote access is not working for HCL users either (especially in the early morning hours until 9:00 a.m. CET) which I don't understand..... Why is remote access not working in the early morning but for the rest of the day???
    /emoticons/default_icon_evil.gif" alt=":evil:" />
    Sorry to repeat this but nothing has changed as of now: I am on HCL and have already reported in another thread (
    It seems that the remote access is not working today.. is anyone else experiencing this?? running HC2 with 4.042. Can access from the internet nor my IPhone. I can login using teamviewer to my PC at home and see that HC2 is running ok.
    Guest chaicka
    Similar experience here... Remote access is on and off whole of today. HC2 4.048, iPhone Fibaro app 2.5.
