stevenvd 51
Does anyone know how to distinguish the difference between a Fibaro Wall Plug and any other Binary_light with power metering functionality from the Json code?
Here I mean the Json code from:
I can see that is is a Binary_light
It is from Fibar Group
Now it can still be any other fibaro relay module
It uses parametersTemplate 225 which is only used by the Wall plug... But what if a new version gets a different parameter?
You can see what color is added. Which probably only for the RGB LED ring...
Any other ways to make the difference? to bad it doesn't show the device type:FGP111 Plug
/emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />4 answers to this question
