fibaro:getModificationTime()
StarkJohan
I'm struggling with this function. Documentation seems to be incorrect or outdated. What is the syntax and why is my simple test returning an error as can be seen?
think you have found a bug or docs issue...
will
get you going
  • Ok, that was my suspicion. Your tip works fine as a workaround, in fact it was how did it before I found the dedicated function (which will be easier to use e.g. when comparing different devices to each other to see in what order things have happened.)
    Added this to the bug thread.
