ouside light/dsrk sensor
akatar
witch sensor does people use to tell the hc2 if it's light or dark outside?
i want to buy one, but haven't got a clue what sensor works in hc2
6 answers to this question
AEOTEC / AEONLAB Multisensor 4-1 DSCB05 is a good choice, but you must install it under the roof for example, not directly exposed to bad weather
/emoticons/default_icon_wink.gif" alt=";-)" /> With DSCB05 you get Light, Humidity, Temp and movement.
regards,
  • hmm i really need it outside.
    i need to know when it's dark around my house (not sunset etc) because i want my outside lights on when it's dark
    i did use a ms13 and later on a "klik aan/uit" device that sends an off/on command
    I have two of these but did not mange to get them working properly with HC2.
    regards,
    Me too... Also Known As: "4 in 1". It's a IP42 device. So it should be protected from (direct) rain, but it can be installed outside. I have one outside and it works well. It currently has no "template" for parameters, but it's functioning in HC2.
    Take a normal light sensor like one mounting on light pole along the street.
    connect the output circuit to a FGS211 switch and you'll have the switch closing when darkness arrive
    then you'll be able to play scenes to light all your external light and if you like power off/on them by your phone.
    enjoy.
    alessandro
