EdwinK 0
Since i've upgraded from 3.570 my aeotec multisensor reports wrong values for light/humidity/temperature. The lux level varies around 450 (midnight or sunlight) and the temperature stays around 15 degrees celcius while its freezing outside
/emoticons/default_icon_sad.gif" alt=":-(" />I've never had any issues with the sensor, and since the problems started after the upgrade i think it's a software issue.
I was hoping it would fixed again in newer versions but i'm now on 3.574 with the same problem. Re-adding the sensor als doesn't help ...
Has anyone else ever had similar issues?
[ Added: 2013-12-17, 22:26 ]
Re-adding the sensor a couple of times more fixed it ... strange stuff!
/emoticons/default_icon_curve.gif" alt=":-/" />0 answers to this question
