GlennNZ 0
Hi
For the life of me I cannot happily get the Aeon energy monitor version 2 working correctly. I have the AU 3 clamp version. The Model number is DSB28xxx-ZWUS -- not the more common version 1 DSB09104-ZWUS version.
Standard install recognised as version 1.2 (?old version) - shows huge value for kwh that is wrong - 233 or so. Modify multiple settings - get watt and kwh shown but don't accurately reflect changes.
I wonder whether this is being recognised as the version one model - the version one model has quite different control parameters as I have discovered.
Compared to the version 1 model version 2 parameters settings are quite different - particularly the binary aspects - 101, 102 and 103 parameters
Link to difficult to find version 2 Specs:
I have successfully worked my way through changing parameters from binary to decimal etc. and can change the reporting - but HC2 still does not actually reflect change in power usage. the Kwh seems correct but Watt reading the main thing displayed by HC2 is wrong.
I suspect the problem is I don't know what the HC2 expects format, data wise and the three child devices are also confusing.
Does anyone know or have these settings for ideally the version2 device or even the version1 and I can try to work backwards?
I have attached the
= output from the main(id 116) and the three child devices below.Thanks for your help!
Glenn
8 answers to this question
