Touch Switch can use or not
iTrustNetwork
Our customer ' d like to use touch switch " Livolo " .
but we not sure this swich will be use with relay 2*1,5 kw or dimmer fibaro or not >
So we 'd like any expert person who can advice us on soon .
13 answers to this question
Yes I think you can use switch or dimmer.
But that is very nice touch screen. Maybe better to buy one before and test.
These switches don't give potential free terminals, Fibaro relay can not know if switch is ON or OFF position. As these switches always take small current from the load(ON or OFF) to operate the touch switching.
If touch switch has neutral connection and gives potential free contacts, it will work. These switches don't work.
  • Thanks a lot Mr.Prateek .
    Do you have the other band for recommend ?
    [ Added: 2014-01-06, 21:22 ]
    We can connect Liviolo switch by you need to use Fibaro Bypass.
    Thank you Fibaro supporter who advice us .
    [ Added: 2014-01-06, 21:24 ]
    In attachment Fibaro supporter include diagram for 2way swtich
    hi
    i have question :
    whit this solution, its work ?
    from the switch livolo and from the HC2 (web app) ?
    tks
    Interested in how the use of the Fibaro Bypass works - do they pass a small amount (25W) of current from the live connection back to the Fibaro and Livolo?
    From what I've seen, the 2-way Livolo switches work by passing A and B wires to the Intermediate switch. I can't figure out how the diagram works as a 2-way.
    Also, using the Dimmer 2 and the Bypass 2, what would it look like?  I guess I could still use the old Bypass as it's serving a different purpose here.
    hey guys, good news, it is all working now. It needs to use new Livolo potential-free switches, but it can be done without any issues. See our blog and video here:
    I dont see Livolo producing "potential-free switches". The closest one is Livolo curtain switch (LV-C702W, 2 buttons). Can you point me to the right switches or suggest any other manufacturer who works with Fibaro switches?
    Hey Guys,
    how can i integrate a fibaro 213 Single Switch in an livolo 2 GANGS - 2 WAYS (3 DIFFERENT LOCATIONS) System.
    thx
    Hello, I need a diagram to connect the Fibaro single switch, to a Livolo 1 gang 1 way.
    The diagram from Fibaro don't work with my livolo switch's, the livolo switch don't work only the fibaro switch work with this diagram, thanks.
