Use VoIP in scene
Guest imparator
Guest imparator
Hi, I get VoIP working, but is there a option to use it in a scene ?
If yes , please send a example please !
Can someone please explain me what can be done with Voip panel in HC2 ?
Guest imparator
    Hi emariu
    you can use it as phone, like Skype, but i think only local network.
    some example :
    you have a video door phone that supports SIP/VOIP, some one press the button,
    it will call you on your mobile phone or house phone(if it works with voip) so you can answer the person in front of your door.
    you can test it if you will with 2 devices like iphone or android phone.
    make 2 users in voip panel, like
    Voip nr: 1001
    Password : 1234
    Voip nr: 1002
    Password : 1234
    then download linphone on your iOS or android device
    in linphone :
    User name = Voipnr see above ( 1001 )
    Password = Password above ( 1234 )
    Domain = ip of your HC2 ( example . 192.168.0.200 )
    after you put everything in linphone save and restart your HC2
    if everything is ok, you can call user1 with 1001 press call in linphone user2 , vice versa
    Hi emariu
    some example :
    Voip nr: 1001
    Password : 1234
    Voip nr: 1002
    Password : 1234
    in linphone :
    Thank you, I understand now..but it's not very usefull for me, anyway
    Local LAN access is not what I need, because SIP or voip intercoms are very expensive and I would have liked to make my intercom ring me on my mobile phone, to talk to the person on my door gate.
    I have a www. voip provider(SIP) that I would like to use with HC2 when the door button is pressed>My ip camera on the gate has also audio microphone incorporated,maybe I can use that in my scene?
