I plan to use an FGS-211 to control my gate, the motor provide an 24v DC power source and i plan to use it.
I don't find any documentation on how to wire the power source on the fibaro module.
I think use this wiring scheme :
L : 24V
N : GND
I : GND
O : Open/Close command
I've tested with a manual switch, the GND - Open/Close command work as described in the motor manual.
Somebody as wired FGS-211 with 24V ? the L-N polarity are good ?
Thanks in advance,
Steve
Hi
FGS-211 no work in 24V DC ,you must connect L-N=220V AC
But, if you connect +24v on 'I' and -24v on motor
Like that
    If you look at power supply spécification you can see :
    Power supply
    110 - 230 V AC ±10% 50/60Hz
    24-60V DC ±10%
    it's very confusing, i found some thread in polish forum, but with "google translate" i'm not sure of the text.
    Maybe someone had already tested or fibaro team ?
    Steve
    Power supply
    24-60V DC ±10%
    Maybe someone had already tested or figaro team ?
    Steve
    effectivement,je viens d essayer et ça fonctionne
    donc sur L=+ et N=-
    Merci - Thank You
    I will soon receive the modules, and don't have to put a new 220v line.
    Thanks for testing.
    Steve
