Hello All,
I am looking for values that can be sent to FGRM-221 devices.
I'd like to be able to modify the angle of lamellas of venetian blinds using LUA.
Thank you
Hi
If it the same that the fgr it goes from 0 to 100. If you want to test, you can set an angle manually in hc2 and then do an getvalue in lua or in event panel.
Steve
    Just tried and figaro:getValue(id, "value") returns the same value in both case, even though the lamellas aren't in the same position.
    dynek, for lamellas use value2
    Fantastic A.Socha, works perfectly, thank you!
    Is that kind of stuff documented somewhere ?
