Sony Smartwatch 2 & Fibaro HC2
Guest sztywniak
Yesterday I purchased smartwatch
Here are the effects of first use
first screen : front camera
second screen : back camera
third screen : button to start the scene: "close the home"
used :
- 2 x camera Vivotek
- 1 x Samsung Galaxy S4
- 1 x Fibaro HC2
- Tasker (autoremote)
- Voice TTS IVO
This is Great stuff!
Can you share a small guide how did you achieve this?
Guest sztywniak
    You will need :
    Android smartphone
    Tasker (
    Tasker extension for smartwatch (
    Voice TTS Ivona or other (
    Voice for Ivona English (
    IP CAM Viewer (application for cameras
    Remote Widget (
    • 4 weeks later...
    You will need :
    Android smartphone
    Tasker (
    Remote Widget (
    How are you programming your http commands in tasker?
    I have found the correct API and HTTP commands, i im struggling to get tasker working properly.
    Currently i have used the HTTP command in a "browse url" command in a tasker task. Problem with this is that it actually opens the browser on the device wich is annoying. Is there a way to execute HTTP commands in tasker without opening the browser?
    Guest sztywniak
    in Task section
    + NET --> HTTP GET
    Server : admin:admin@HC2_IP
    Path : /api/sceneControl?id=SCENE_ID&action=start
    Nice! Thank you
    in Task section
    + NET --> HTTP GET
    Thank you very much. Works like a charm
