Better way to handle French VMC using Fibaro
kiwi
I had made some LUA script that make my VMC (French systems that is running on all houses to exhaust humidity).
I have a single way VMC, so instead of make it working all the day, I will ask it to start it when a room get more that 5% more humidity than the average.
I have 2 speed : low speed and high speed. Since the VMC is made with main speed (that should be on all the time), then ask it be high speed, you need to have 2 switches. I used a FGS-221 for that.
I have 4 Everspring ST814 used as humidity sensors.
Here is the code, there is still some debug on it, you'll have to update it with :
hum_cap : the humidity module...
vmc_low : the VMC low speed module
vmc_high : the VMC high speed module
Xavier[/code]
