Dimmer with LED, optimal steering impulse (parameter 20)?
Default value in Fibaro Dimmer for steering impulse (parameter 20) is 110 (for 50hz).
At the same time vesternet (
) recommends another value: "we've found that it should be set between 134 and 140 for LEDs to work well".
It is important to set this parameter correctly, because as I see in fibaro's FGD221 manual: "Wrong setting of the function may cause incorrect operation of the Dimmer".
So, what do I need to set up this parameter in order not to hurt both dimmer and dimmable LED lamp?
In my particular case I have 11W LED lamp (
) with bypass. They work fine with P20= 110, 134 or 140. So what to use for better stability?
