Sync RGW
Hello
Do you know if it's possible to sync 2 RGBW module together ?
You need to change these lines to the id of the master:
%% properties
1229 color
1229 value
%% globals
%% properties
1229 color
1229 value
%% globals
Heh, thanks for the reply! Was just coming back here to say what mistake i'd discovered and you've beaten me to it
/emoticons/default_icon_cool.gif" alt="8-)" />
Also found
earlier which has a slightly more simple script but doesn't support multiple slaves out of the box.
Shame the HC2 has a delay for the scene picking up the device changes - means switching off has a delay per device rather than all together.
Think i found a bug with the script.
If i turn on my RGBW from the web UI using the brightness slider it doesn't trigger the scene to turn on the other RGBW controller for sync.
I'm guessing this is to do with the %% properties thing at the top ?
This should also work if you add those lines.
