Door Sensor Scene
I am trying to make a scene regarding opening the bathroom door with a Fibaro door sensor insalled on it. I have the logic set up for this but since I have no knowledge of LUA scripting whatsover, I am having a hard time implementing it properly (one time it even made my HC hang, had to reboot it, probably went into an infinite loop of some sort).
The scenario for this would be as follows:
1-Open door to enter bathroom, light turns on.
2-Close door behind you, light stays on.
3-Open door to exit bathroom, light stays on.
4-Close door behind you, light turns off.
Using the traditional scripting I have done before this could be done easily by setting a variable (flag) for the status of the door and just working from that, I can do that with my limited LUA knowledge (2 hours old
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> ) but I dunno how to set more than one "then" and I need that.
Also I would be glad to have suggestions as to how I can optimise this scenario since I know it has some "loopholes" like if the door is opened and then he closes it without entering, light stays on indefinitely or if he opens the door to exit but then closes it while still inside.
Should I just drop this whole idea and just use some presence sensor? or combine it with one?
7 answers to this question
Due to the loopholes mentioned, I on my part decided to implement "door open: light on for x minutes" in my cellar (multiple rooms). For a single room a presence sensor could be better for the same cost.
A script already exist in the forum.
    Thanks for the reply, can you suggest a good presence sensor that works well with HC2?
    if you don't close the door the first time the light wil stay on for ever
    or you open door, remind to do something else. go away and close it again, same problem
    better is using a pir
    when pir breach
    reset timer
    start timer 10 min
    after 10 min light out
    this can be done in homeseer, i don't know if hc2 supports timers and reset that timer
    this way every time you move in the bathroom the timer starts again with 10 min
    so a long shower won't turn the lights out
    Guest GG
    you have one solution for having a timer in HC2.
    In this case, I use a pir from Satel alarm system, but it could as well be any other trigger you want to use to trigger the light with.
    Door sensors, PIRs or other sensors all helps building an "intelligent/smart" automatic system. The thing is, it is allmost impossible not to end up with one or more loopholes. To me, bottom line is to determine when is enough enough ("good enough). And - ah yes - I preferably also have a manual type/sw/(simple scene) to override...
