WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
Mobile apps fully working with this version:
- iPhone app - version 2.1.1 (available on the App Store),
- Android phones app - version 1.3 (available on the Google Play),
- iPad app - version 1.2 (being reviewed in the App Store, available soon).
3.580
- Testing connection with Satel alarm.
- Faster HC2 booting.
- "Undo" button after predefined alarm scene has started.
- PIN codes added to alarm (warning: PIN code will be reset after this update and has to be set up again).
- Information from Fibaro icon added.
- Entry time and exit time in Fibaro Alarm.
- Excluding sensors from alarm system.
- Excluding devices from events history.
- Possibility of setting sensor as always armed or always disarmed.
- Changes dedicated to mobile apps new versions.
- Importing gateways - information about connected gateways.
- Possibility to change temperarure unit.
- Importing / exporting virtual devices.
- Network settings fixes.
- Virtual devices changes and fixes.
- RGBW device fixes.
- Backups creating fixes.
- Virtual devices update - sleep in main loop increased to 3 seconds.
- Fibaro Alarm fixes and changes (i.e. always armed / always disarmed, multi arming / multi disarming devices, excluding sensors from alarm system, configuring sensors).
- Stopping scenes and blocking saving scenes and devices while alarm is active.
- Fixed searching for other HC2 units in local network.
- Other minor bug fixes.
Bugtracker tickets:
- 0000077: Logi
- 0000141: Włączanie alarmu z iOS
- 0000398: Error uploading .png icons
- 0000413: HC2 show me 0.01 W usage for one fibaro dimmer Turned OFF !
- 0000414: HC2 show me 0 W usage for one fibaro 3k switch Turned ON but 10W declared !
- 0000522: In API field "type" appears twice in properties node, sensor, binary light etc.
- 0000531: Show the scene in interfaces changed to "No" without notification -> scenes not visible in Iphone & Android app.
- 0000585: Device Declared power consumption does not work sometimes
- 0000631: 3.548 json.encode crashes in virtual device
- 0000723: 'modified' field in /api/devices is not updated with new timestamp after device state changed
- 0000742: Add delayed trigger to alarm panel
- 0000757: Extra options for "device kind"
- 0000942: Alarm Panel Problems
3.571
- Minor bug fixes.
3.570:
- New json library in LUA.
- User icons in remote access.
- Z-Wave bug fixes.
- Fibaro FGFS101 Flood Sensor support.
- Importing devices from other HC2 gateways (gateway connections).
- New virtual devices with support for iPad and Android apps.
- Changes dedicated to iPad v1.1 application and new Android application.
- Support for new Fibaro FGR221 Roller Shutter module.
Bugtracker tickets:
- 0000899: Can't turn off potential fire and freeze notifications
- 0000511: SP814 template (broken)
- 0000142: Everspring ST814
- 0000782: After HC2 restart/upgrade the RGBW module is shown as 'On' in GUI
- 0000882: Virtual Device popup
- 0000890: When setting new value for ID of a slider(not tested for other controls) the old ui..value tag in JSON is not removed
3.558:
- RGB panel added.
- Fibaro RGBW Controller support.
- Added notifications (email and in UI) about devices low battery level.
- Support for iPad application and new Android application.
- Added possibility to sort sections, rooms, devices and scenes in configuration interface.
- New Event Panel - TimeLine.
- Possibility to move views in Dashboard.
- Possibility to change the type of binary sensor, e.g. motion sensor to smoke sensor.
- Information about last state change of the sensor (e.g. door).
- Fibaro Alarm panel added.
- Added possibility to reset device energy data.
- New languages: Russian, Danish, Finnish, Chinese.
- Bug fixes in showing and configuring power measurements.
- Bug fix in saving Advanced mode of GPS position reading frequency.
- Bug fix in showing information on the map in Family panel.
- Bug fix in VoIP panel - fixed logging in as system user.
- Z-Wave bug fixes.
- Aeon Labs 4in1 bug fixes (attention, in case of not working properly, device must be re-added to the system).
- Other minor fixes in UI and translations.
Bugtracker tickets:
- 0000080: Cameras do not display in IE10
- 0000200: Can't use a binary sensor as an input for bell push in video gate.
- 0000325: Parameter 42/45 representation of wallplug in GUI messed up
- 0000390: Rooms icon
- 0000419: Brak aktualizacji w zakładce pomieszczenia
- 0000488: fibaro:killScenes(ID) doesn't work
- 0000494: Wrong energy usage descriptions in energy panel
- 0000510: call wakeUpDeadDevice in scene seems not work as expected
- 0000515: Problem w wyznaczenia godziny wschodu i zachodu słońca
- 0000519: decimal points or comma's in variables panel
- 0000550: Don't mark as dead node option not saving
- 0000544: LUA 'Attention' dialog rendering
- 0000545: Improve alarm panel labels used in 'status' drop down
- 0000546: Device name length needs to be enforced when editing
- 0000556: złe tłumaczenie
- 0000590: Energy panel settings tab has a save button
- 0000596: Dashboard General Main sensors show Wrong DEAD
- 0000602: no ptz actions with a foscam like camera
- 0000647: Problems with setting associations
- 0000667: In dashboard view Danfoss thermostats are counted as dead
- 0000673: In General Panel on Dashboard all FGK101 Door/Window Sensors counted as doors even if change device kind to window sensor
- 0000678: fibaro:log not work in devices panel "/fibaro/xx/devices"
- 0000679: Aktualne zużycie energii
- 0000719: Can't use private icons for window sensor
- 0000769: Error message in dasboard
- 0000778: Missing translation
- 0000784: in german translation no values in devices configuration
3.548:
- Changes related to new version of operating system repositories.
3.547:
- Fixed bug related with some cameras problems in remote access mode.
3.546:
- Solved 503 Error issue appearing for some users.
- Fixed working of scenes based on user location.
- Fixed energy graphs in live mode.
- Solved problem with diacritics symbols in devices/rooms/scenes names.
- Other system fixes.
3.545:
- Fixed displaying image from Home Entry System Helios.
3.544:
- Possibility to run scenes by Lili (please reload Lili database in configuration after update).
- Remote access scripts watchdog added.
- Added possibility to choose triggers in block scenes.
Bugtracker tickets:
- 0000487: Add/Delete GPS Points Error.
- 0000480: GPS condition doesn't work.
- 0000476: Panel ogrzewania przestaje.
- 0000460: Heating Linked Device fails to switch off Switch 2 (a.socha) - rozwiązany.
- 0000459: Modified variables don't show up in scenes.
- 0000454: Variables with space can't be changed.
- 0000437: EnergyPanel date select.
- 0000426: Option to deactivate variables as scene trigers
- 0000424: Bad slider position (cosmetic) in dashboard / actuator panel.
- 0000418: Błędne przekierowanie w trakcie tworzenia scen opartych na pozycji GPS.
- 0000403: headline.png not found in linked device panel (head of menu).
- 0000402: Unable to save new state of predefined variable value in dedicated panel.
- 0000396: Belka nazwy panelu domofonu.
- 0000387: Impossible to access the HC2 web page from iPad.
- 0000380: On the HRT4-ZW the temperature reading is being used as an energy reading.
- 0000369: Translation needed: Home Entry System Panel.
- 0000350: uprawnienia użytkownika.
- 0000341: Bad energy costs in energy panel header when switching from power usage to energy costs.
- 0000331: Temp value of HRT4-ZW as energy usage in bar and panel.
- 0000328: Camera Panel when "Remote Access" is selected
- 0000288: SOme scenes can't be saved and disappear.
- 0000274: Modular Alarm Panel - iOs control and Users.
- 0000268: Modular Alarm devices can no longer be selected in Scenes.
- 0000245: no keyboard editting lua scripts via the iPad.
3.517:
- New, quicker and future oriented system architecture.
- Rebuilded, faster configuration interface.
- Faster communication within Z-Wave network. Faster system reaction for devices states changes.
- Improved, much quicker sending commands to devices via the iOS application.
- Quicker scenes execution.
- Added support and debugging for Lua scripts.
- Automatic conversion from graphic block scenes to Lua scripts.
- Added possibility for Lua debugging.
- Sending sms/email/push notification from scenes.
- Integration with Satel alarm.
- Added support for new device types.
- Energy panel and managing devices with energy measurement.
- New, extended mobile interfaces.
- Power consumption options in block scenes.
- Additional options in video cameras.
- Z-Wave tab in configuration.
- New device inclusion window, informing user of new device configuration stages.
- Helios intercom support
- VoIP panel
- Information top bar and Dashboard - subpage with configurable information views
- New drenchers panel
- Views from cameras in Your Home section
- Possibility to manually add theoretical power consumption for devices not supporting power metering, visible in Energy Panel too
- Support for new device types, new device parameters.
- Modified scenes main screen.
- New Virtual Devices version - now you can add a button or slider executing Lua script.
- Changed configuration interface layout
- Moreover 3000 minor bug fixes and improvements.
  • Answers 102
  • Created
  • Last Reply
Try pressing reconfigure button at the advanced parameters. This has done the job for me many times before.
Hi
I have just updated to 3.580 and it has worked out good for a couple of days, but now when i was typing in new messages for alarms all stuck and when i restarted there is nothing in the fields.
Anyone knowes what has happen and what i can do to solve it
The update did execute according to my expectations. The question I have at this time is about the firmware update of my RGBW modules. It seems that the behaviour of the device is correct until now (previously it did corrupted network traffic when under heavy load, e.g. turning on all lights to max, controlling other devices whithout being reqeusted as such).
Now my questions:
- At what stage of the HC2 upgrade the module gets updated?
- What is het new firmware version?
- What happens if I downgrade the HC2, does the module gets downgraded, do I have any possibility to resore if new problems occur?
- Will newly added devices be upgraded automatically?
Thanks!!
Bas
Some issue very strange, I Have 3 Secure SRT321, since I have upgraded to 3.580 they don't change the temperature even if the Heating pannel are correctly configured.
See graph :
Will investigate....
Hi
Same thing happen to me.. but i just log in... no modify in progress.
You have to push the power button in HC2 once and let it shut down. Then push it again and it will works again.
Hope in a fix soon! That's a big issue!
Hi
Hi
I have tryed that, restarted several times but everything was very slow and nothing was visible of what i have in the system, so went in to recovery mode, and went back on a earlier backup, which came up good, but then i updated to 3.580 again, and then the same problem one more time...
Was this version made available for app Beta testers?
I have found out the editing scenes doesn't work with internet explorer 9.
It only displays a selection between nlocks and LUA when trying to edit an existing LUA scene.
Also, the setting "Do not allow alarm to stop scene while alarm is running" displays diffrently in ie9 and chrome, see attached images.
These two images represent the same, existing scene, when viewed in IE9 and Chrome.
I have the same problem. IE9 can't be used anymore for scene editing with R3.580. Mozilla Firefox works OK.
Replying to myself : the issue with my SRT321 has gone after reboot and removed a dead everspring smoke detector.
there are more modules polling doesn't work anymore.
the duwi wallswitches (not .me)
and the normal duwi plugin modules doesn't work either
they were working 2 updates ago
There is another improvement that does break the functionality in my scenes.
Writing a global variable does update the global "last write timestamp" at each write. Since the update this seems only the case if the value changes. Why this change in behavior????? Simply storing sensor active status in a global variable does not provide perfect timestamping anymore. I can work around, but it is less clean....
Bas
Great news!
Anyway I am not able to upgrade via home.fibaro.com, when I press Start upgrade button nothing happens, there is a way?
Regards
Domenico
P.S. Happy New Year to Everyone!!!!
Same problem for me. I click on Start but nothing happens. Tried several different browsers but problem still exists. Any suggestions?
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> (My HC2 is on version 3.575 right now)
Thanks in advance.
EDIT: I logged on locally to the HC instead of via home.fibaro.com and now it worked fine.
Has somebody already received an update of the iPad app?
Nope it's in the approval process in Apple's hands.
Hi all,
I wonder how the new stable release supports the New Fibaro Smoke Sensor.
E.g. Black box support, Alarm support?
B reg
Camme
Good work Fibaro
This is for me the most stabile version since 3X
All the options are working fine in my have loaded HC2
Only some error logs that some devices don't exist.
Hope this can also be fixed soon.
I have different issue, after the upgrade to 3.580, some of my devices: RGBW, FGS211, FGFS101 on 12V power and Danfoss valves go dead or into panic mode. I never had this issue with previous versions of your software. What is surprising all of these are powered devices (except for Danfoss) and there were absolutely no power failure during that time.
HC2 reports stable uptime of 3d, 18hrs which is basically time since update. Are there any known issues, or is the anything I can do to bring stability back to my system.
I have another issue.
I have a virtual module that has this in the main loop :
Now I am almost sure that the virtual module lost it's main loop after random amount of time.
This didn't appears on 3.573. This bug has been raized after 3.574/3.575 (when the sleep has been added on the main loop).[/code]
I have the same issue - MainLoop stops processing after a seemingly random amount of time.
Introducing a sleep makes it last longer, but it still fails eventually.
I have the same issue - MainLoop stops processing after a seemingly random amount of time..
Same for me in 3.580
Never used before so I don't know when it was introduced !!!!
