Sous vide with HC2
rantta
I was planning to test how Fibaro Universal Sensor works in the kitchen, when cooking
Now on the earlier setup I have crock pot, thermo controller and PT100 control sensor probe, with about 20 cm metallic tip, which I can dip into water. Something like this one:
With Universal sensor I have to change the probe. DS18B20 temperature probes seem to be shorter, like this one:
How well does the rubber isolation stay in shape, when I dip it to ~55-80 °C water? The probe should work up to 125 °C, but how will that be, when I practically boil the probe sometimes for days, over and over again? Will the probe last?
Or is there longer probes available? I did search, but did not find…
4 answers to this question
  • Thanks!
    I allready ordered some probes, we'll see how they work.
    One reason for building sous vide application with HC2 is that so I can alter the temperature also remotely, if plans are changing. More heat in hurry, but I can also drop heat, if I realize that the actual cooking will happen day later than planned.
    Hi rantta
    Interesting idea.
    I do a lot of SV but never thougt about cooking with HC2.
    Please keep us updatet - and good luck
  • Thanks! I will update this when this will progress.
    At the moment I'm emptying my freezer, there is some pork tenderloin in the sv
