To light the lamp with lua code
Guest nohed
if you want to turn on or off multiple lights with a lua code how should the code look like then
ID should be changed into the id of the device you want to turn on. For each device you want to turn on, you should add a line with the deviceID.
If you want to turn them off, you should change turnOn into turnOff.
