candrea77 26
This simple script is used to auto cutoff power to standby devices.
In my house I found some device (TV Decoder, WIFI printer and so on) that when in standby consume about 20W.
So i've placed a wallplug on every device and with this script i don't need anymore to disconnect the power after their usage .... the script do it for me !!!
HOW TO USE IT :
devices : put your devicesID that need to be controlled.
minpower : for every device in devices, specify here a watt value that is < of the standby power consumption.
timer : for every device in devices, specify an amount of time that need to be on before the cutoff.
names : for every devices, specify the name of the device (only for LOG)
Script autorun every 180 sec .... tune it if you prefer to run more or less frequently !!!
For logging normally I use a global variable called DEBUG : set it to 1 in order to enable log.
7 answers to this question
