Camera question
Tcheri
If I want to view my cameras from outside (direct access), I need a public IP.
My ISP ask me 6€ per public IP per month.
If I declare my cameras in my Fibaro HC2, can I remotely access my cameras from outside (home.fibaro.com) without a public IP per camera ?
Thierry
5 answers to this question
Yes. As soon as you configure your cameras in HC2, then you can also access them remotely.
My camera is local (192.168.0.xxx) and works OK from iPhone. But it is important to have a wifi.
Public IP you need only in case if you plan to access your cameras not using HC2 (connection to via camera's web server directly).
Tcheri,
You can also have only one public ip for 150 camera. You just need to change the port on your router
But yes you can have access to your camera from fibaro app.
You can also use DDNS...
And if you have not bought cameras yet, I suggest using DLINK ones with the mydlink app that allows you to access your cameras without any need for a public IP, the Fibaro system has limitation in public access, it will not provide you with live video stream rather a jpg refreshed every few seconds (default is 3 i think).
Regards
  • ahmad89,
    I had a fix IP address, but not public, meaning impossible to reach from outside my italian ISP.
    DDNS does not solve that issue.
    Since I took the option, now it's public (and access from anywhere in the world).
    I can use multiple ports as written above.
    And I have tested : the HC2 play the role of proxy : so from home.fibaro.com, I can access my cameras even without any port forwarding or public IP.
    Thx
    Thierry
    Oh sorry I thought you had a public IP but just not static, giving customers a private IP is quite unfair, most ISPs give public IPs to all customers just not a fixed static one, I work for an ISP and that's how we do it.
    Anyhow i hope the lack of live video stream limitation in remote access does not bother you with HC2 and would then allow you to discard the need for a public IP.
    Regards
