Door Sensor Override
Hello
I have just installed some more door sensors on my windows/doors....
Is there anyway that i can have heating panel to pause -- if during heating a window or door opens up.... ( heating is done via Fibaro relay switch )
christos
[ Added: 2014-01-07, 17:50 ]
/emoticons/default_icon_question.gif" alt=":?:" />
[ Added: 2014-01-08, 17:24 ]
i have tried creating a scene to stop the heater relay switch but it doesn't seem to be working
why is that??
[ Added: 2014-01-09, 14:42 ]
well i have tried the following which seems to be working but don't know if it is right way to do it
i have created a virtual device with slider in order to change temperature in heating panel
then with the help of the following scene if the door/window is breached i just tell it to set temperature to 5 degrees forcing my heating pump to switch off
else set the virtual device to 0 forcing the heat panel to get the pre programmed values
now the only drawback i see here is that if i manually set the temperature and then i open the door, then when i close it again the temperature does not get the manual value i have set but the temperature from the heating panel
