I had to make a restore on my system and right after that i made a update to 3.580.
The system now see all my Dimmers FGD 211 as it should under Device TYPE, but under device KIND they all comes as a sensors.
I can choose from 5 different kind of sensors but not a dimmer and i can't find any way to change this.
Any solution on this ?
Try to reconfigure these under the parameters. If this do not help try force update button under configuration panel.
    Thanks for the reply.
    I tried both. When trying to change parameter the system say that the sensor is in alarm and parameter can´t be change before alarm is reset. ??
    Any other solution ?
