Just tested the Philio sensor.
it’s a nice small sensor with lot of function using the latest wave protocol 6.0 like Ezmotion and Aeon
Only one option works at the moment with Fibaro HC2. (same problem as the Ezmotion 3 in 1 sensor)
Motion/Open/Close
See my Dutch review
Google translation
I have the sensor as well. Temperature works too but you have to read it from the log line, or create virtual device. Lumens cannot be read. You can configure it as door or motion sensor, it makes no difference. Movement or door open will send open, and movement timeout or door close will send close.
And the best part, for me: it will turn on lights on door/movement but only when the room is dark! Works great, just add the parameters as documented.
  • 1 year later...
Hello
can you give us some info about your setting for it?
because i try to use but also if i putted the parameters like guide of vesternet...no way. i see only in my device but nothing works.
i use these:
Configuration Parameters Parameter No. 2 Size 1 Default -1 Name Basic Set Level Description Setting the BASIC command value to turn on the light Type range Values -1   ->   0xFF(-1) turns on the light. 1 - 100   ->   For dimmers 1 to 100 means the light strength   Parameter No. 3 Size 1 Default 70 Name PIR Sensitivity Description parameter to set the Sensitivity for the PIR (Passiv Infrared Sensor) Type range Values 0   ->   0 means disable the PIR motion; 1 - 99   ->   1 means the lowest sensitivity, 99 means the highest sensitivity   Parameter No. 4 Size 1 Default 99 Name Light Threshold Description Setting the illumination threshold to turn on the light. When the event triggered and the environment illumination lower then the threshold, the device will turn on the light Type range Values 0   ->   0 means turn off illumination detected function And never turn on the light. 0 - 100   ->   1 means darkest. 99 means brightest. 100 means turn off illumination detected function. And always turn on the light   Parameter No. 5 Size 1 Default 0 Name Operation Mode Description parameter to set the Operation Mode Type range Values 0 - 127   ->   Bit 0: 1 means security mode; 0 means home automation mode. Bit 1: 1 means enable test mode; 0 means disable test mode. Notice: Bit0 and Bit1 will effect when the DIP Switch setting to program mode. If Bit1 is enabled, the Bit0 is useless. Bit 2: Disable the door/window function. Bit 3: Setting the temperature scale. 0: Fahrenheit, 1:Celsius Bit 4: Disable illumination report after event triggered. Bit 5: Disable temperature report after event triggered   Parameter No. 6 Size 1 Default 4 Name Multi-Sensor Function Switch Description parameter to set the sensor functions Type range Values 0 - 127   ->   Bit 0: Disable magnetic integrate illumination. Bit 1: Disable PIR integrate Illumination. Bit 2: Disable magnetic integrate PIR (Default is Disable) Bit 3: When Bit2 is 0 (Enable), the device is install in the same room with the light? 0: In the same room(Default), 1: In the different room. Bit 4: Disable delay 5 seconds to turn off the light, when door/window closed. Bit 5: Disable auto turn off the light, after door/window opened to turn on the light. Notice: If bit2 is zero, this setting is useless. Bit 6:Enable temperature monitoring. When this bit enable, the temperature changed 3 degree Fahrenheit, it will report. And also the temperature over 140 degree Fahrenheit, it will report every 64 seconds.   Parameter No. 8 Size 1 Default 3 Name PIR Re-Detect Interval Time Description In the security mode, after the PIR motion detected, setting the re-detect time Type range Values 3 8 sec - 127 8 sec   ->   8 seconds per tick, and minimum time is 24 seconds, default tick is 3 (24 seconds).   Parameter No. 9 Size 1 Default 4 Name Turn Off Light Time Description After turn on the light, setting the delay time to turn off the light when the PIR motion is not detected Type range Values 4 8 sec - 127 8 sec   ->   8 seconds per tick, and minimum time is 32 seconds, default tick is 4 (32 seconds)   Parameter No. 10 Size 1 Default 12 Name Auto Report Battery Time Description interval time for auto report the battery level Type range Values 1 30 min - 127 30 min   ->   30 minutes per tick and minimum time is 30 minutes, default tick is 12 (6 hours)   Parameter No. 11 Size 1 Default 12 Name Auto Report Door/Window State Time Description interval time for auto report the door/window state Type range Values 1 30 min - 127 30 min   ->   30 minutes per tick and minimum time is 30 minutes, default tick is 12 (6 hours)   Parameter No. 12 Size 1 Default 12 Name Auto Report Illumination Time Description interval time for auto report the temperature Type range Values 1 30 min - 127 30 min   ->   30 minutes per tick and minimum time is 30 minutes, default tick is 12 (6 hours)   Parameter No. 13 Size 1 Default 12 Name Auto Report Temperature Time Description interval time for auto report the temperature Type range Values 1 30 min - 127 30 min   ->   30 minutes per tick and minimum time is 30 minutes, default tick is 12 (6 hours)
thanks for all
