double-clicked
Guest nohed
Guest nohed
how do you do so that the switch does things when double-clicked
I haven´t got it to work myself but this:
and this:
should work.
I don´t know if it´s my switches that is to old. If you are trying to use S2 on dimmers you need v1.9+ and i only have v1.7 units
EDIT: Got the first one to work now
/emoticons/default_icon_mrgreen.gif" alt=":mrgreen:" /> I think i forgot to check the scene as "Active Scene". Maybe the second one also will work if i do it right...
/emoticons/default_icon_redface.gif" alt=":oops:" />
I add two values as described and changed line 3: to my id and line 190: to what i wanted it to do (run another scene that turns on my staircase lightning). Now im going to add more features.
