I am having a problem with one of my Fibaro Door Sensors.
I have created a script for each Door Window sensor which is triggered when the value of the sensor is changed. This is done by defining the "id value" in the header of each script:
The script simply sends an email with the value of the door sensor.
This works fine for the majority of door sensors but I have 1 sensor that behaves differently. When the sensor is breached the blue led blinks 3 times (scene gets triggered 3 times) and when the sensor is unbreached it also blinks 3 times (scene gets triggered 3 times again).
All other door sensors only blink 1 time when breached/unbreached and their corresponding scene is only triggered once.
Does anybody have an idea what can be causing this strange behaviour?
Thank you.
