Hello!
I am using a scene to slowly dim a light from 50 -> 0 over 10 minutes.
But, this means that when I press the S1 switch, the light does not light up, as it is “turning on” with a level of 0. Yes, you could double click and go to 100%, but try to explain that to a three year old kid with bad dreams… :=)
Is it possible to set a parameter to tell the light “Start up at 40 next time”?
Don't know how dimmers work but I'd say:
Either: catch the "push" event when turning off the lamp to set default to 40 when somebody pushes the button next time
If that's not possible because if you do so the light turns on when setting value then: catch the event when turning on the light to automagically set value to 40 if it equals 0
This can be done using scenes with triggers.
    "Set the default", yeah, but I cannot find a parameter which does this.
    " catch the event when turning on the light to automagically set value to 40 if it equals 0" I connot really do this, as S1 is hard wired, is it not?
    "hard wired" = button, that's what you mean ?
    You can catch the event using the ID of the dimmer and then check its value.
    Hello!
    could you please share your code for this?
    Hello!
    Sure, it's dead simple and has no overrides tho..
    [/code]
    My code, based on yours.
    I've add two last lines to restore to normal level.
    I have side-effect: blink of light on "SetValue,99", but very-very short and not for full power, and then it turns off.
    After that, when I press physical button to turn on light - I have 99% level. I prefer 99% since dim max level is 99 in configuration. Maybe 100% work as well.
    BTW, your script works much faster than 10 minutes. About 60 seconds from 50% to 0%. I think 50*1200ms=60 seconds, not 600.
    I left 1*1000*50=50 seconds for test purpose in my version.
    I have no idea how can be done without side effects.
    [ Added: 2014-01-18, 00:30 ]
    more testing done.
    Please notice that
    fibaro:call(lampID, "setValue", 0);
    is totally equal to
    fibaro:call(lampID, "turnOff")
    Since level 0 is not possible. min level is 1.
    So, final code for your 40%, 10 minutes
