MINIMOTE AEON LABS DSA03202W USE FIBARO BY FIBARO KRAKOW
Guest Paweł Świerczyński
Like always short presetation using minmote with hc2
Cheers !: )
Invite to subscribe yt and facebook
I am unable to add minimote to my HC2. I am getting 'Learning mode error. Try again.' What should I do? Any help will be appreciated.
Have any of you tried to configure the remote control "Aeon Labs Minimote Remote Control", I did not succeed, I followed to the letter the instructions at "http://www.vesternet.com/resources/application-notes/ APNT-42 #. UvS4Hnnv49s "result does not work.
thanks
I had "Learning mode error" few times. Then I just removed it from HC2 and resetted the minimote, and tried again and again, until it registered the device right.
I also had to wake up the Minimote few times before the configuration was done.
I've managed to set it up more or less following the same procedures, but now I would like to make it work but I can not activate any commands while following the procedure explained in the link "http://www.vesternet.com/resources/application-notes / APNT-42 #. UvTd43nv49s "
I would like to turn the two commands of a FGS221 Switch 2x1, 5kW EU - ID 38
But it is possible that in the forum Fibaro there is not anywhere a standard configuration to make it work - as you can find in the forums of competition.
my configuration is:
  - HC2 - 3,581
  - No. 2 FGS221 Switch 2x1, 5kW EU
  - HRT4-ZW
  - Everspring
  - No. 3 FGK101 Door / Window Sensor
  - No. 5 Danfoss Living Connect Thermostat
  - DSB05xxx ZWUS Z-Wave Multi-Direction
My LUA-script for Minimote (ID 49) is something like this:
Pretty simple on/off -commands so far, works ok.
