Decoding JSON
Hi everyone,
I am trying to pull a few values out of a json response from another source. I already found many examples but they don't seem to work for me.
The LUA script so far:
I want to pull 3 values marked in bold. I know it should become somthing like this, but not sure how exact:
current_usage = response.body[1].states[2].value[4] (or am I completely wrong here??)
current_total = response.body[1].states[2].value[??]
current_gas = response.body[1].states[2].value[??]
The unsorted json response:
Any help is welcome
12 answers to this question
I haven't played yet with JSON on HC2 so this might not work but it looks to me like what you want is:
# Watts
current_usage = response.body[1].Device_Num_77.states[0].value
# KWH
current_total = response.body[1].Device_Num_77.states[2].value
# GAS
current_gas = response.body[1].Device_Num_77.states[3].value
Hope it's correct
    Unfortunatly does not seem to work. Is there a way to debug a bit more which actual value this is pulling?
    Maybe this helps:
    Pass it the body and see what comes out.
    errrrr, paste this into my HC2? Or how do I parse the body there?
    I moved bold tags inside the quotes to have a working JSON bit.
    Then here:
    Proves I should be right
    Ok, So apart from my attempt to make a bold number (hence the code) the problem may be that it is in quotes when trying to write it to a variable....
    Guess more stripping required then
    [ Added: 2014-01-14, 15:14 ]
    but with or without body?
    current_usage = response.body[1].Device_Num_77.states[0].value;
    or
    current_usage = response.Device_Num_77.states[0].value;
    does not write the any value
    fibaro:debug(response.body[1].Device_Num_77.states[0].value)
    fibaro:debug(response.body.Device_Num_77.states[0].value)
    fibaro:debug(response.Device_Num_77.states[0].value)
    Try them all
    First 2 attempts:
    [ERROR] 15:32:14: line 6: attempt to index field 'body' (a nil value)
    Last attempt:
    [ERROR] 15:34:08: line 7: attempt to index field '?' (a nil value)
    So still a no joy
    [ Added: 2014-01-14, 16:35 ]
    So, I created a virtual device and assigned 1 button. In this button I programmed this LUA:
    Unfortunatly there is no debug option in here and it does not change the number in the variable panel. If I use another value:
    It correctly updates the value to 1.
    Not sure where the difference is .......
    Maybe the index starts from 1, then:
    fibaro:debug(response.Device_Num_77.states[1].value)
    BINGO!!!!!!!!!!!!!
    Thank a gazillion!!!!!
    My pleasure
    Now that I have it working (sort of) I want to clean up my code so that I can share it to others and have them easily customize it.
    The original code:
    The goal:
    Most of it actually does work, except the pasring of the JSON_WATTS/JSON _GAS bits.
