Question about Param 41 on Fibaro dimmer FGD211
If i set Param 41 is set to "Activation of the functionality", does that mean that S1 loses its normal operation?
I would like S1 to work as it always has (control the load connected to the dimmer module) and use S2 for scene control.
Any hints on how to do that in the most efficient way?
JanJoh,
It will not loses its main functionality. You can use it as you've mentioned.
    JanJoh,
    Aha, in that case, the text is a bit missguiding in the web interface. Because when i read it it appers that both buttons will Always send scene activation?
    But, I thank you for the clarification.
    Krystian,
    FGS switch does not have this parameter, do they always call scenes?
