Unexplained error with "getRoomNameByDeviceID"
Hi All
I have strange message when I use "getRoomNameByDeviceID" function !!
Here is my code :
and here is the error message
[ERROR] 16:03:38: line :getRoomNameByDeviceID (arg 2), expected 'unsigned int' got 'nil'
I tried using an other variable in line 3 but I have the same error...
But the script works fine (I get my room name) !!! so I wonder what's happen !!!
Any idea ?
David
4 answers to this question
Quikdav,
    Thanks for the reply.. it works fine
    /emoticons/default_icon_redface.gif" alt=":oops:" />
    I don't understand why this error occurs when I save the script !!!
    I would understood if I had launched the script manualy but it is not the case !!!
    because you dint have any if before, so script was work every save
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
    ok thanks, I keep this in mind
    David
