Smoke sensor temperature
Guest sk8er000
hello,
I've recently bought the fibaro smoke sensor and i'm really satisfied of it and it's really well made, but unlike the flood sensor it desn't have a separate icon for the temperature and is showed in the bottom of the sensor's icon. In the mobile application the smoke sensor's temperature is not showed at all.
is it possible in the future updates to have a separate temperature like the flood sensor?
thanks in advance
sk8er000, yes we gonna do that with 4.x update
Guest sk8er000
    Perfect!
    Thank you very much for your hard work I really appreciate it!
    Good news!
    A.Socha - can we use then smoke sensor also with heating panel?
    Lauri, in 4.x yes, it will be separate temperature device, and you will be able use it in heating panel
