i bought a door/window sensor, after 2 weeks batt low
i bought a flood sensor, after 3 weeks batt low
i just bought a smoke sensor, hope it last longer then that
so whats the expected life of the battery operated fibaro moduels?
is 3 weeks normal? i don't want to replace the battery's every three weeks
or is it just bad luck?
There is something else I think. I have door/window sensor on my door with DS18B20 over 6months now and battery level shows about 75%, same with Flood sensor.
Have your devices properly configured?
    yes, they are properly configured
    maybe just bad luck
    But when you installed the devices - how was battery status then?
    Have you changed any parameters or wakeup time?
    when i bought them, i added them and changed nothing
    next day 75%
    my visonic sensors work for months (almost a year now)
    hope that the smoke sensor is better, i wanted to change all my visonic smoke sensors for the fibaro's
    if battery life is less then a couple of months i'm keeping the visonics
    I have 6 Door sensors , for 6 Month now , they are still at 75 % so I am sure you have a problem with yours
    hmm, just bad luck.
    i will see what happens, if the smoke does the same then it's a one way trip to the dump
    I have the same problem with my door sensors and 1-2 flood sensors. After I installed new batteries in them and they all ran for months already. Seems to me batteries quality problem and nothing to do with the system or devices.
    I had this on one of my door sensors too, after I moved to HC2 (worked fine for weeks on another controller). After excluding it an reincluding with a new battery, it's been running fine for months. Seems to me something went awry during inclusion.
