Horstmann room HRT4-ZW thermostat SRT322 problem with HC2
novos
Hi dear team, Fibaro Home Center 2.
Today I have buy this device Horstmann room HRT4-ZW thermostat SRT322 + Receiver.
I have connect Receiver to Boller system with power and S/R contact. All work fine with two devices.
I have goo to my HC2, add this device.
1) Termostat added good and see in HC2.
But together add Receiver I can't.
Or it be work with HC2 or with Termostat only. How resolve this problem please?
I need like add two device to HC2, and two device need work together too.
And one additional question please: How manage biller temperature with HC2?
Thank you.
5 answers to this question
  • Hi i think config good.
    First I have add Termostat to HC2.
    Second add Reciever to HC2.
    Without together added this devices in one wave.
    After I goo to HC2 center and config In the Advanced tab associate it with the Secure Receiver using Group ID 2 set. Correct?
    And then I have know managment thermostat from HC2, only, But when I scroll it, HC2 view this temperature are changed.
    All see good? With my config?
  • One additional question please:
    What is time here 1h 0min ? After temperature on screenshot.
    In a manual/standalone mode the timer will not do anything. But if the thermostat is controlled by a heating panel in HC2 and you manually override the program from the thermostat then this timer will show for how long time it will overrule the heating panel in HC2.
