Problem with FGD-211 and connect before transformer 220V
Problem with FGD-211 and connect before transformer 220V after he convert to 12V to LED lamp. I have connect dimmer on this install screen has attached, but when I click on HC2
OFF dimmer I see flashing lamp then blink all time. When I click to
ON dimmer I see good ON lamp work. But in Offline it blink every time.
Please help me, have any idea to config dimmer, or this dimmer not supported
transformer/converter 200V to 12V ?
[ Added: 2014-01-20, 19:01 ]
I see this problem here
But do not understand how fix this?
Can you add different Neutral cable? The problem is that Dimmer needs power and if you installed it 2wire way then there is always small current running through lights.
Another option could be the bypass.
Please use Neutral wire and try to modificate parameter 20 for higher values.
    I don't have Neutral in box only L/L switch to LED lamp(( That is problem are?
    How fix?
    How fix?
    The only "real" fix is to get an electrical installer to provide a N in the Connection box.
