Fibaro RGBW Controller with external RGB Controller
Guest pablotibis
Hi, I want to control RGB led strip with controller fibaro, my question is: can I enter in the inputs of the controller fibaro an external RGB controller to be used for example when you do not want to use fibaro, the controller is one of the photo attached. If so, how should I proceed? I saw that the "in" fibaro are 0v-10v instead of the RGB controller with up to 12v I leave I do not know if I'm wrong.
[ Added: 2014-01-27, 16:29 ]
no answer?
no answer?
[ Added: 2014-02-14, 12:04 ]
no answer?
no answer?
  • 4 months later...
i think it will not work, since output of "normal RGBW" controller is just pulsation of 12v impulse at 244hz. and fibaro RGBW expects 0-10v of stable dc.
  • 1 month later...
I found a "mostly working" solution for that in a German Blog Post. Maybe you can use Google Translate, but there are also Pictures which explain the Idea and setup.
Maybe this can help you....
Guest pablotibis
    wolfster thanks, I read your blog to understand your solution, google definitely will help me.
