Black Box recordings
antamaga
HC2vr. 3.580
ipad vr 1.2
OPERATING MANUAL
SMOKE SENSOR
FGSS-001 v2.1 - v2.3
The Fibaro Smoke Sensor has a built in memory for recording smoke and
temperature information. Having recorded even the smallest amount of smoke, the
sensor records the smoke level measured, time and temperature measured at that
precise moment. This information is sent to the Z-Wave network main controller
every 60 seconds. Home Center 2 allows for monitoring Black Box recordings (see
below figure).
Where can I find the display window?
fig. 5 manual -
5 answers to this question
Fibaro support:"Black box will be available in 4.X soft of HC2".
ok, good to know, thanks
What's black box?
it's the fact that sensor (like smoke sensor) can store internaly there own value. (like smoke)
HC2 will have a specific panel to read them call "black box".
see below.
ooh smart. Not sure I'm seeing the usefullness of it though.
surely you only care about when the detector raises the alarm, not smoke levels that were below the threshold.
I'm sure that someone has a use for it, I guess I'm curious about what that use is
