I want to encode this in LUA,
{"cmd":[25, 1]}
How to do this... (feel really silly asking
/emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />)
jsonString = {cmd = "25,1"}
json = json.encode(jsonString)
fibaro:debug(json)
4 answers to this question
I'm not entirely sure on what you are trying to do, should the value be this string "12,31" or are you trying to set multiple values to a single key?
Either way, I've attached an example of usage. This example is multilevel as can bee seen in the "devices" key.
    Thank you for that example. This is not a made up system, I have a API saying to send code:
    I have the code, but no clue how to encode them correctly
    Then I think the syntax you need is this:
    Keep in mind json.encode/decode only works in virtual devices, not scenes.
    Ok, so far no success with my script. I tested my connection via putty (RAW) and it does seem to work. Just need the translations.
    Putty: IP 10.0.1.199 PORT 4242 MODE RAW
    How to translate this to LUA?
    [ Added: 2014-01-29, 15:10 ]
    Tried this but no luck. I guess maybe I am missing the end of line thing? ^@ is created in putty with CTRL+@ then I hit enter
    [ Added: 2014-02-25, 17:18 ]
    Still no luck finding my end of line. Any clues?
    [ Added: 2014-02-25, 20:50 ]
    Ok, problem solved. Had to add \0
