I have added some smoke sensor to my systeem.
After some startup problems they are working fine.
I had to add the sensor using external DC power.
After that I removed the external power and inserted the battery.
Now the smook sensor are always awake.
Is the a possibility to change this without excluding / including?
TANE, nope, on inclusion device showing is he battery or DC, even if you change power controller will always treat device that same like on inclusion
    Sensor are showing DC power...
    okay will try to exclude include again..
